Suspension Bushings for Dino Coupe 2400
MaseratiSD
Post by MaseratiSD »
Hi All,
Its time to change all the suspension bushings on my Dino 2400 Coupe. Is there a source for those parts? Does it make sense to switch to Poly bushings?
Also,
What about the brake proportioning valve? The ends links on it are shot, is there a standard fix for the links?
Re: Suspension Bushings for Dino Coupe 2400
Check Superformance in UK as they have nearly all bushings available. I have build in theirs. Dinoparts also have Most of the bbudhins. As the Proportioning valve is Stück in man case and is cheap as well you should change it too. I know no Source for poly bushings that fit. I can also imagine that they are too hard.
MaseratiSD
Thank You,
I will check both out. Is there a source for the proportioning valve? Also, My proportioning valve end links are just about gone, does anyone have a photo of what they are supposed to look like or who might sell those parts?
Barnfind
Post by Barnfind »
I have recently seen some on ebay.
