The original clips (2 per side) looked as though they were part of the titanic. I purchased some galvanized sheet metal and cut it to a slightly larger size then bent the edges over for more strength.
Then put a curve into it and made a hole for the bolt. Stainless steel hardware.
If the fitting was too loose I just had to flatten the curve a little.
A simple job
