Oils.
Barnfind
Oils.
Post by Barnfind »
Hello..
I'm quite interested to know what oil are you using in the 2400 diff and Gbox.
Regards..
AndyC
Re: Oils.
Post by AndyC »
Fiat Selenia FL Teutela W90/M-DA 80w-90 in diff.
Millers Classic Gear Oil 80W/90 GL4 in gearbox.
There are many perfectly suitable choices for the gearbox, but as I understand it, the Fiat stuff is the ONLY one recommended for use in the diff.
Andy
Barnfind
Re: Oils.
Post by Barnfind »
What type of diff has the Dino 2400:
Limited slip (Discs type). Fergusson or Torsen?
Thanks..
Re: Oils.
Use in the Diff only only only the recommended W 90 M/DA! Other oils, also if recommended for lim slip diffs will cause noisy operations.
Re: Oils.
where can you get such oil in the us? Superformance is not shipping oil to the us..
Re: Oils.
I bought it from a local Iveco (Fiat Trucks) Dealer. Is there anything like this in the US?
As it is not a special classic car oil it should be able to get it.
Barnfind
Re: Oils.
Post by Barnfind »
Ok. Fair enough.
I'll try to find it in local truck shops.
Thanks.
Re: Oils.
Barnfind wrote: I'll try to find it in local truck shops.
It might be hard to find in any local truck shop since it seems to be Fiat-/Iveco-specific. Anyway, I've attached the data sheet that you can specify it exactly when looking for it.
1452_scat_ENG.pdf
Tutela W 90/M-DA data sheet
(118.08 KiB) Downloaded 833 times
doublegarage
Re: Oils.
Post by doublegarage »
I'm in the US and I used Amsoil gear oil
http://www.amsoil.com/shop/by-product/g ... e=AGLQT-EA
with limited slip additive
http://www.amsoil.com/shop/by-product/g ... e=ADATB-EA
That cured all the noises from the rear end. It was all part of my big "drivetrain vibration" problem, but that's all in another thread.
doublegarage
Re: Oils.
Oh and in the gearbox I used Amsoil GL4 oil
http://www.amsoil.com/shop/by-product/t ... e=MTGQT-EA
GL-4 and not GL-5 because there are apparently additives in GL-5 (Sulphur, I think) that can damage brass synchronizers like our ZF gearbox has.
Yes I really like Amsoil products because they work really well and are actually what they say they are (real synthetic, not "synthesized" from normal oil-stock or mixed) and no, I don't work for them.
