Oils.
Re: Oils.
Fiat Selenia FL Teutela W90/M-DA 80w-90 in diff.
Millers Classic Gear Oil 80W/90 GL4 in gearbox.
There are many perfectly suitable choices for the gearbox, but as I understand it, the Fiat stuff is the ONLY one recommended for use in the diff.
Andy
Andy
Re: Oils.
It might be hard to find in any local truck shop since it seems to be Fiat-/Iveco-specific. Anyway, I've attached the data sheet that you can specify it exactly when looking for it.Barnfind wrote: I'll try to find it in local truck shops.
- Attachments
- 1452_scat_ENG.pdf
- Tutela W 90/M-DA data sheet
- (118.08 KiB) Downloaded 832 times
- doublegarage
Re: Oils.
I'm in the US and I used Amsoil gear oil
http://www.amsoil.com/shop/by-product/g ... e=AGLQT-EA
with limited slip additive
http://www.amsoil.com/shop/by-product/g ... e=ADATB-EA
That cured all the noises from the rear end. It was all part of my big "drivetrain vibration" problem, but that's all in another thread.
- doublegarage
Re: Oils.
Oh and in the gearbox I used Amsoil GL4 oil
http://www.amsoil.com/shop/by-product/t ... e=MTGQT-EA
GL-4 and not GL-5 because there are apparently additives in GL-5 (Sulphur, I think) that can damage brass synchronizers like our ZF gearbox has.
Yes I really like Amsoil products because they work really well and are actually what they say they are (real synthetic, not "synthesized" from normal oil-stock or mixed) and no, I don't work for them.
